1994 390CPMY w/Kohler 6.5
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
I checked the fuses on the unit, and the 10A glass one for CHARGE was blown. I shut off breaker on unit and same thing, it would start and not stay running once I let go of the switch. I did have the entire cover off to add coolant and check oil. The GENSET has been very reliable until this past weekend, and it has 225 hours on it. I am wondering what may have happened? I will remove the entire cover again tomorrow and see if I knocked a wire off or something silly. However, I am also puzzled why the unit wont stay running even if I have the breaker on the GENSET shut off.
Always something. I would welcome any comments that may evoke some thought for me!
Be well and stay "charged"!
Re: 1994 390CPMY w/Kohler 6.5
- tonyiiiafl
- tonyiiiafl
I got a couple of Chinese made ones from AMAZON from a company in NJ, but they arrived opened and look like they were returned. So I went to the source for the brand that was on there and found them in Arizona, so overnight to arrive Friday. I am going to install the new contractors and see how that goes.
Update to follow, and stay tuned!!!!!!!
- tonyiiiafl
Now once the unit runs, it is slow to go to 120V. It shows perhaps 40V, then if I place a load on it, (water heater, it will shoot to 90-100, and then once loaded, it goes up to 120V and runs great, powdering anything I toss at it.
Upon starting, the top left and top right red LED’s light up, the bottom left and right do not. When I shut unit down, the bottom 2 light until unit is off.
Time for a Kohler guy to come down? I need to get the manual and see about that circuit breaker too. Just strange it ran great a week ago, but if it was low voltage, that would indicate why the contractors were slow to pull in?
- Has thanked: 603 times
tonyiiiafl wrote:Source of the post Time for a Kohler guy to come down? I need to get the manual and see about that circuit breaker too. Just strange it ran great a week ago, but if it was low voltage, that would indicate why the contractors were slow to pull in?
In this case a wise idea....from my small understanding of these gens ..... Unloaded...If idle rpm is correct and the gen puts out 60cycles, you should see 120 at the panel....The guy will/should be able to check all these relationships.
- tonyiiiafl
tonyiiiafl wrote:Source of the post I am thinking the capacitors (or one of them ) is bad. I have voltage, and it comes up as a load is placed. Just need to research where and how. Then I may give that a shot before calling in the high priced Calvary. Thoughts?
I would agree with this.
- tonyiiiafl
