Need Info re Head on 1993 300 Sedan
- Dusty Bilges
- Vessel Info: Carver 300 Sedan
- Has thanked: 20 times
- Been thanked: 8 times
My bride is staying on the boat up on the Canadian border and I'm a couple hundred miles south and get a call from her; the handle on the head's pump broke off. I am hoping I can go up there before next weekend and hopefully just replace the pump or top of the pump. All I know is that it appears to be a Raritan, but I don't know which model. I attached two photos she frantically took a few minutes ago.
Anyone knows which model it is? Anyone know if you can just buy the pump unit and not the whole head?
Any help highly appreciated.
Dusty
Re: Need Info re Head on 1993 300 Sedan
you can rig something to that metal rod and just pull it up and push it down to pump. Won't be the most convenient, but it will work. The linkage they have there just gives you some leverage (which is also why it's easier to break).
That little bolt hole in the side is where the electric motor option linkage bolts to the plunger to do the pumping for you.
You could also make a replacement fairly easily. THe only reason that's more complicated is so that it has a removable handle. If you didn't need (or want) to remove the handle you could just fabricate a handle out of a 1' long piece of stock.... you could probably use a hardwood like Oak, some strong plastic or even a section of aluminum. You just need to drill two holes for the pivots.
- Dusty Bilges
I believe the "E" in the model number PHE-II stands for the electric version. Same toilet and pump but with a couple of brackets that hook up to plunger instead of the handle.
- Dusty Bilges
- Been thanked: 490 times
A buddy bought 2 new Norcolds in one year. Learned about the cooling kit after the first brand new one burned out.
