Oil pressure gauge malfunction?
chdugan
Vessel Info: 1999 Carver 350 Mariner with twin 350 Mag engines
Postby chdugan » July 22nd, 2019, 4:30 pm
Hi Folks,
I was returning home from a weekend trip yesterday, when all of a sudden alarms started going off, so I throttled down to find out what was going on. I saw that both oil pressure gauges showed almost no oil pressure, so I shut down the engines. After checking the oil levels, which were good, and visually inspecting the engines, I decided to start them and see if the issue would continue. I fired them up and the oil pressure gauges read normal. I got up to cruising speed and had a pleasant cruise home. I'm thinking that there was a malfunction of the controller for the gauges, or some kind of short. Any have any ideas or have had a similar issue?
Thanks,
Chuck
1999 326 MY
Re: Oil pressure gauge malfunction?
Postby Viper » July 22nd, 2019, 5:55 pm
Are they Mercruiser? Can you post a serial number?
Return to “Electrical”
