Dometic STX12
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
Dometic STX12
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: Dometic STX12
- tonyiiiafl
Re: Dometic STX12
- Has thanked: 603 times
Re: Dometic STX12
Re: Dometic STX12
A pet peeve of mine is water in the AC tray. I always have modified or corrected the unit by shimming it so water flows almost entirely out when at rest at the marina as a base. No matter how you slice it or dice it, standing water becomes stagnant which is not a good thing. Maybe just a clean up and rethink the drain on your unit is all that is needed.
- tonyiiiafl
Re: Dometic STX12
- tonyiiiafl
Re: Dometic STX12
- tonyiiiafl
Re: Dometic STX12
Re: Dometic STX12
tonyiiiafl wrote:Source of the post...perhaps a bad bonding wire. I have to hunt that wire up....
I don't think there is one.
On first glance it looks like salt deposits so my first suspicion is that you have a raw water leak. Disconnect the raw water inlet and outlet, plug one end and make up a rig to do a pressure test. Then you'll know for sure.
Re: Dometic STX12
