Swap out a 12K unit with a 16?
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
Re: Swap out a 12K unit with a 16?
Does this unit service just one cabin or two?
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
As it is with everything boat related, everything is a trade off, too much or not enough. Hard to find good balance.
- BenTen
- Vessel Info: 1984 Carver 3697 Mariner - "We'll Sea"
- Has thanked: 20 times
- Been thanked: 32 times
In my climate the 12k unit is only large enough for cooler days and evenings and cany keeping on hot days, even when working with the 16k unit on. I have a 16k going in eventually as well to cool my main cabin, bunk cabin and head.
HTH
Ben in SC
- tonyiiiafl
You should also look at the cooling water flow. If your current unit can't keep up, is it possibly starving just a little bit on the cooling water flow? You might fix that and solve your problem. If the current flow only supports a 12K unit, you might have to upgrade the pump (and potentially hoses) to fully satisfy the 16K unit.
- tonyiiiafl
- BenTen
Ben in SC
On my previous 32 express I had a single 16,000 btu unit. It was OK but struggled in hot temperatures. Not that it did not work but you did needed to keep the entrance door closed for it to be nice and cool down there. I figured the newer stuff must be improved and that my older unit probably lost a little efficiency over the years. I started shopping around and stumbled on MarinAire. Spoke with the owner who recommended I go with a 14,000 btu unit which I thought rather odd since he was going smaller than what I had? I followed his recommendation only to realize the new unit was freezing up, I enlarged the plenum to except more air and increased the size of the main duct which corrected the issue 100%. Holy moly what a differance. The 14,000 btu unit really performed well, in fact I was able to leave the door open now and it no longer struggled in hot weather.
Bottom line, our units are old, the serpentine gets dirty inside to a point where cleaning is difficult, the compressors get weak as well as the circulation fan. We tend to bandaid the unit here and there however replacement after 15-20 years is probably your best option IMHO. That being said, my AC runs 24/7 when at home port, I like to keep the cabin slightly cool and control the humidity levels in the boat when we are not there. I do dial it down cooler when we arrive at the boat though.
I ordered 3 new units for Midnight Sun over a year ago. The unit in master suite was replaced this spring and all I can say is what a difference in cooling capacity and even more so noise wise as they are really quiet. I chose to go 14,000 for the main as opposed to 16,000 and the forward unit which was an 11,000 was replaced by the same size. The master suite had a 7,000 which I upped to a 9,000. Overall the BTU output has remained the same. Will eventually get around to replacing the remaining 2 units.
I have recommended these units to quite a few people who were all really impressed after installation. This is MarinAire. https://www.marinaire.com
- mjk1040
- Been thanked: 248 times
