Replacing Holding tank on 1994 Voyager 320
audcarver
Vessel Info: 1994 32 foot Carver Voyager--new owner
Postby audcarver » August 6th, 2019, 5:41 pm
My holding tank is leaking. I have had the boat one month. I can see the "water" leaking at the bottom exhaust fitting. Preparing to remove tank to determine if is fitting or tank. Current tank was install in 2001. It is an aluminum 33 gallon tank. The dimensions are 21L,20H and 17W. It takes up all of the bilge space between gallery and head. As I look for tank that will fit in the 17.5 inch width opening, the largest I have found is 20 gallons. it appears that current tank was custom made. Any and all guidance is very much appreciated.
Re: Replacing Holding tank on 1994 Voyager 320
Postby tomschauer » August 6th, 2019, 5:52 pm
I personally would find the biggest poly tank I could fit. I wouldn't stick with aluminum for the holding tank.
Postby bud37 » August 6th, 2019, 6:12 pm
I agree....a nice heavy gage poly tank is the way to go, fittings in the top, vacuum breaker etc.......no AL for waste....bonus is you can see the tank level with the plastic.... :-D Trionic makes lots of sizes, maybe some custom.....
Postby km1125 » August 6th, 2019, 11:18 pm
You can get 40gal and I think 50 gal tanks that have a max dim of 17" on one side.
Users browsing this forum: No registered users and 37 guests
