New Boat Owner - Need help with kohler Generator.
- mobinakhtar
- Vessel Info: 2003 Viking Princess 65
1988 Carver 3207 Convertible
1971 Hatteras 38 Convertible
2005 Boston Whaler 15 Montauk - Location: Freeport, TX
- Been thanked: 7 times
Re: New Boat Owner - Need help with kohler Generator.
- Has thanked: 603 times
mobinakhtar wrote:Source of the post Bud37, I do not see the ground wire and my engineer friend also expressed concern about one missing. I will take close up pics of the solenoid next time showing wires.
You have a bigger unit than the one I have therefore perhaps not exactly the same, but I think if you follow the ground ( black cable from the battery negative) back to the generator you will see if there are any connections, corrosion etc and how it is grounded to double check as that area under the unit can be fairly dirty.
Just cross the simple no cost things off the list first.
- kamakazerc
- Vessel Info: proud new owners of a 1988 3607 aft cabin,as of august 2018, and still have at this time our 1980 mariner 2896
- Has thanked: 3 times
- Been thanked: 8 times
Good luck !!!!
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
kamakazerc wrote:Source of the post If you can crank it by jumping the solenoid than probably not the ground or the solenoid! But still worth cking and cleaning. I'm going with bad relay under the black box, and or maybe just dirty connections at the relay....
Good luck !!!!
We haven't heard from the OP in two months. No idea if he resolved his problem
- mobinakhtar
- mobinakhtar
Update 12/1/2020 - sold the carver. Bought a 65' 2003 Viking. Big upgrade
mobinakhtar wrote:Source of the post I think I got taken by this tech guy. H charges almost 7K but got the genny going. replaced entire fuel system, eelctricals, and electronics except the engine (meaning he didnt know shit and swapped everything for new). I basically had to pay 7K to get my gas genny back from him. at least it works now.
YIKES! Yes, I think that tech guy needs a lesson in troubleshooting!! Aside from the control board, they are not very complicated.
Congrats on the Viking!! Those are nice boats! (er, SHIPS!)
