Windlass up/down switch
Captain Kirk
Vessel Info: 2004 Carver 360 Super Sport
Has thanked: 8 times
Postby Captain Kirk » August 17th, 2019, 2:21 pm
Gotta lean on the Carver community for some help with my windlass. 2004 360 SS, Maxwell 880 windlass. Everything works except the down switch on the helm. Both foot switches work and the up control on the helm switch works too. After troubleshooting, I replaced the switch and still have the same result. :banghead:
Thank you for any guidance you might have.
Re: Windlass up/down switch
Postby tomschauer » August 17th, 2019, 8:30 pm
Maybe a bad connection at the relay board?
mwest74
Vessel Info: 1995 330 mariner w crusader 350xl's
Has thanked: 10 times
Postby mwest74 » August 18th, 2019, 10:40 pm
Do you have or can you get wiring diagrams for the windlass switch circuit? If you do, a continuity check is a simple thing to do. This would tell you if the wire from the switch to wherever it goes, i.e. a relay is good. If the wiring checks good, then you know you have a component issue. I could take a look if you can get ahold of the schematics.
mwest74
Postby mwest74 » August 18th, 2019, 10:41 pm
Do you have or can you get wiring diagrams for the windlass switch circuit? If you do, a continuity check is a simple thing to do. This would tell you if the wire from the switch to wherever it goes, i.e. a relay is good or not. If the wiring checks good, then you know you have a component issue. I could take a look if you can get ahold of the schematics.
Postby g36 » August 21st, 2019, 1:18 pm
Did this ever work for you? If not I would verify that common is on the center terminal on the switch. If it's on either outside terminal then you will get operation only in one direction as you are describing.
Return to “Electrical”
