Fuel sending units
- 1992330aftcabin
- Vessel Info: 1992 330 Carver aft cabin
- Has thanked: 54 times
- Been thanked: 32 times
Re: Fuel sending units
- 1992330aftcabin
1992330aftcabin wrote:Source of the post Bud, all original gages.
Considering this, both gauges original and show the same.....
.....tank units have failed at an earlier date, but checks can confirm that....check connections
.....tank units have been changed with a different ohm range than the gauges...have a look for new tank units.
.....as has been suggested, bad grounds or connections but.... both gauges the same ?
.....both tanks are really only half full, but that has been checked.
.....both gauges have failed at an earlier date before the boat changed hands, this will be shown by the gauge check
.... is this a dual station boat with gauges in both stations ?
Keep us posted after the checks.
- 1992330aftcabin
- dkitchen
- Vessel Info: 1994 Carver 350 Aft Cabin
twin Crusader 7.4l - Location: Michigan
- Been thanked: 4 times
I have a ‘94 350 aft cabin, which appears to be the same boat. My gauges read a bit differently, in that the port tank reads half of its starboard brother. Since one gauge works fine while the other does not, I presume the issue is with the sending unit. I was not able to get the port sending unit out while in storage this winter, but it is on my spring list. All of which is a long way of saying: I know how to get to the sending units!
Port side: the sending unit is under a floor hatch that is under the aft end of the couch in the salon. You’ll have to pull the couch to the stair to get enough room behind the couch to get in there.
Starboard side: in the salon, just forward of the stairs to the aft cabin, is a two door cabinet. The rearmost door on my boat opens to a liquor cabinet, with a piece of plexiglass cut with holes in the bottom of that cabinet. Under that piece of plexiglass is the removable bottom of the cabinet. Take out both and you should find another hatch, below which should be the starboard sending unit.
Let me know if I can be of additional help. I’m in Grand Haven.
- 1992330aftcabin
- 1992330aftcabin
Just to let everyone know I feel ethanol was the culprit the plastic bushing was binding with the float rod keeping it from moving freely, I do believe that’s why I only went to 1/2 full on both tanks.
- dkitchen
- 1992330aftcabin
