FRESH WATER COUNTER STOPPED COUNTING
Jfriz
Vessel Info: 1996 355 AFT
Postby Jfriz » July 5th, 2019, 8:37 pm
Hello All!! I attempted to change the capacity setting on the Fresh water counter Under the galley sink, and now it doesn’t count down any more...... any idea what settings should be to get it going again?
Re: Little green light? 355 Aft 97
Postby bud37 » July 5th, 2019, 8:45 pm
Welcome to the forum......have a look in the engine room, see if there is a light on.... :-D
Postby g36 » July 5th, 2019, 9:03 pm
Yep engine room lights
Jfriz
Postby Jfriz » July 5th, 2019, 9:12 pm
Ah! Ok, thanks! Obviously I need to find the engine room light(s) and replace them because it’s dark as hell down there even with the little green light on.
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Postby buster53 » July 5th, 2019, 9:34 pm
Assuming your 355 is the same as my 356, the engine room light is directly underneath the stairs coming down from the aft deck into the salon. You really need to stick your head into the engine room and look up to see it.
I think there is only one, but if you find another, let us know.
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Postby tonyiiiafl » July 6th, 2019, 8:30 am
Took me a year to find that little critter. The light under the aft cabin bed is also controlled by the OUTSIDE switch! That one took 3 years to figure out!
Jfriz
Postby Jfriz » August 23rd, 2019, 1:39 pm
Hey all, another lightning question! Are the Florissant lights 12v or 110? There’s one above the galley sink and one in the front berth. Thanks!
Postby tomschauer » August 23rd, 2019, 2:00 pm
12 volt.
But the bulbs are the same for 12v or 120v.
buster53
Postby buster53 » February 15th, 2020, 12:55 pm
Jfriz wrote:Source of the post Hey all, another lightning question! Are the Florissant lights 12v or 110? There’s one above the galley sink and one in the front berth. Thanks!
Unless you get into the larger yachts, just about every light installed by the factory in boats will always be 12v.
Last bumped by Jfriz on February 15th, 2020, 12:55 pm.
