Advice on bottom paint???
- VicB
- Vessel Info: 1988 Carver 3807
- Has thanked: 41 times
- Been thanked: 11 times
Thanks in advance,
Vic
- AaHubb
- Vessel Info: '99 404 CPMY
- Has thanked: 15 times
- Been thanked: 61 times
Re: Advice on bottom paint???
..Aaron
SeaDragon
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- Has thanked: 474 times
VicB wrote:Source of the post.....It has barrier coat and probably had ablative paint on top of that, but that’s totally gone....
If there already is a properly applied barrier coat then you shouldn't need to apply more unless it's been damaged, it doesn't just disappear. BTW, we shouldn't get into the habit of thinking that a barrier coat will prevent blisters, it won't, it's more complicated then that. The chances of blisters appearing aren't just dependent on external influences but also conditions within the glass layers themselves. As such, a barrier coat doesn't guaranty you'll never get them after its application.
I like ablatives because I hate layers and layers of old useless paint, and I like sanding them even less. If you do nothing, ablatives will simply disappear and leave you with a fresh bottom to start all over with again, even if you wanted to apply a different type of coating. Prep is easy for applying new coats later, just clean the hull. There are pros and cons to different types and the key in choosing is to determine your needs, water conditions, type of boating, your wallet, etc. There are few threads on here with some good info, they should show up if you do a search on the subject.
- VicB
If the hull has been barrier coated previously, you shouldn't have to redo the whole hull again. Simply repairing the current blisters properly and barrier coating those isolated areas again should be fine.
Do you know how many coats of barrier coat were applied initially, and what brand?
- Cooler
- VicB
- VicB
Users browsing this forum: No registered users and 48 guests
