Fridge Maintenance
Fridge Maintenance
So my question is what needs to be checked or looked at to tweak the unit to perform better? I assume checking r134 status is probably the most likely culprit.
darrenlife
- Vessel Info: 2002 Carver 410 Sport Sedan
- Been thanked: 36 times
Re: Fridge Maintenance
I have also researched this topic and some have success after installing an auxiliary fan aimed at the compressor to help improve airflow.
That being said I need to get to the boat to see what if any resistor is installed. Here is the pdf describing the compressor speed. http://www.novakool.com/support/documen ... 007PDF.pdf
- vineyardgray
- Captain
- Has thanked: 128 times
- Been thanked: 33 times
- Contact:
1988 Carver
3867 Santego
PCYC
If it stops, either the the thermostat is telling it the fridge is cold enough or something may be wrong with the inverter board.
Try it on 12v only and see if it gets colder..
Keep us posted
- Been thanked: 654 times
- Has thanked: 603 times
Midnightsun wrote:Source of the post I do agree, defrosting is a must on a regular basis however not much frost in there. Remember, she was on the dry for 6 weeks, all power off. Only been in the water and connected for a couple of weeks now.
Is it possible that you have installed something that is dumping some extra heat into the air space the fridge relies on behind .....can't imagine what but .........how they are loaded can affect them as well...
I have noticed with our boat, that the way it faces the sun/docked really affects the inside wall temps on either side.
