Gas additives for an aluminum tank?
- VicB
- Vessel Info: 1988 Carver 3807
- Has thanked: 41 times
- Been thanked: 11 times
Thanks,
Vic
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Gas additives for an aluminum tank?
Not much you can do about the water/condensation while she's laid up, though there are a lot of products that claim to get rid of the water. I don't know of any product that actually gets rid of water, they mix with it and the idea is to get a product that when mixed with water will also burn along with the fuel. Seafoam is a good product but not very good at doing that IMO, and leaves the water separated out. You also have to be careful with products that contain a lot of alcohol which could exacerbate the water problem if the treated fuel isn't used up in reasonable time. Also increasing the alcohol level in your fuel might start degrading some materials like rubber, seals, etc.
I've always had the best results with products that were labeled as water dispersants. When added to fuel at the beginning of the season, the water is put into suspension in tiny little droplets that the fuel system has no problem burning, but no product will have a lasting effect in your tank forever, the key is to burn it as soon as possible, and the more fuel you have in the tank in relation to water the better. There is a point where no product will doing a thing for a tank with too much water in it and the solution is to simply drain the tank. AND check your fuel/water separating filters often.
I don't worry about octane in the Fall but will add an octane booster in the Spring.
