Rotella T4 15w 40
- mjk1040
- Been thanked: 248 times
Re: Rotella T4 15w 40
Not sure where 1 year comes from since literature from manufacturers say 5 years and this is conservative coming from them. IMHO if oil went bad after a year there would be mandatory expiry dates on the containers.
- Has thanked: 474 times
Engine OEMs don't like you using old oils in their product. One OEM instructor went as far as saying that in a major failure dispute they can and will test for the age of the oil if they suspect poor maintenance or oil change practices are the cause. If found that the oil had recently been changed but the product was determined to be more than a year old, they would have a way out. It used to be major claims were settled with no questions asked, that's not the case anymore with the systems and price tags on today's engines for a couple of reasons. They will investigate.
I guess this is just another one of those things where we all do what we feel is comfortable for us individually. In the end, time is always the deciding factor on whether we made the right decision or not.
Just a personal observation,...I have found no residue on the bottom of oil that has been stored and residue on just bought stuff and the opposite, as a result of this I just turn the bottles around/over a while before before use......don't shake before install, don't want aerated oil in the pan on startup.
In all these years of cars/trucks and racing, I have never had an oil related engine failure, lots of others...
but no oil...At the end of the day, just use what your manual says to use and all will be just fine......hopefully...
tomschauer wrote:Source of the post Darren, I have always run Mobil 1 15/50 full synthetic in my merc gassers. Cheaper than the merc semi, and better oil.
Why did you decide on the 15w50 ?....just curious about the grade difference, not the cost.
The one thing I like about the merc oil is the cold number......boat engines run cold and it takes quite a while to get the engine oil temp up to the point where it acts like the higher number. That said I use rotella 15w40 in everything, but it is still interesting to consider.
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
So here's another can of worms; how many of you have considered replacing your oil twice; both in the Fall before winter layup and then first thing in the Spring because that puts your Fall oil over 90 days? Probably not many because most think oil's protective properties last forever but it's done a lot in high performance applications, why? Because it has a shelf life and in that particular application, it's critical. The guys will change their oil in the Fall with the cheapest stuff they can find, store the boat for the winter, then dump the unused oil in the Spring. They want fresh oil and all the additives performing to spec. Oh and by the way, in their sport, engine failures do happen because of oil breakdown. Ask one of them if they'll knowingly use a container of oil that's been sitting on the shelf for a few years.
Look, I'm not saying that two year oil is useless, or that you'll have an engine failure if you use it, I'm just putting the caveat out there and am perplexed as to why for the sake of a few bucks are we putting something that's been sitting for a few years into our engines. It's such a critical component and we should be taking advantage of every little bit of protection we can. I mean we have lengthy discussions about the best brands and grades to use, the quantity of zinc, etc, etc., and we all know we won't have a failure short term if we don't go with "the best" but we all seek them out anyway for long term reasons, this is no different. I just have a hard time wondering why we spend loads of cash on comparatively insignificant things for our boats but skimp for the sake of a few bucks on critical systems.... and that's my rant for the day
When I first got into boating mechanics I wondered why in the world would one want to change oil in fall as car manufacturers would recommend X miles or 3 months which ever comes first. (times have changed) This implies oil is only good for 3 months when in an engine. Now they want me to change oil in the fall, leave it all winter and run it until next fall! Did not make sense to me until I was explained how all that bad stuff such as condensation, humidity, combustion residue and whatever else is in the contaminated oil would be working away at my engine all winter long. Now that made sense so I went the change in fall route as it most likely does the least damage in the long run.
Viper wrote:Source of the post So here's another can of worms; how many of you have considered replacing your oil twice; both in the Fall before winter layup and then first thing in the Spring because that puts your Fall oil over 90 days? Probably not many because most think oil's protective properties last forever but it's done a lot in high performance applications, why? Because it has a shelf life and in that particular application, it's critical. The guys will change their oil in the Fall with the cheapest stuff they can find, store the boat for the winter, then dump the unused oil in the Spring. They want fresh oil and all the additives performing to spec. Oh and by the way, in their sport, engine failures do happen because of oil breakdown. Ask one of them if they'll knowingly use a container of oil that's been sitting on the shelf for a few years.
I have done exactly that and did it for many years, mainly because I am anal about engine cleanliness, but and there is always a but......It really is wasteful in these times we have. Waste oil is very expensive to recycle and for the most part there is no valid science that supports all these oil changes based on time alone. I believe sending samples to a lab for verification is probably an eye opener and the best course, especially with diesels and those giant sumps
Here's a question.....Aren't all the additives in the oil supposed to help us with all these things ?
Users browsing this forum: No registered users and 48 guests
