396 Aft waste tank hose access
- thatchh
- Vessel Info: 2004 Carver 396ES gas Crusader 8.1
- Has thanked: 5 times
- Been thanked: 11 times
I am preparing to change all the hoses to the aft waste system in my 2004 396. Two of the long hoses in the system (toilet to vacuum pump, and pumpout line) connect to PVC pipes way down in the bilge. About the only way I can see to access those fittings is to remove the port muffler. Anyone have any tricks or suggestions to avoid that big job? If I remove the cabinet next to the bed, would that give me some access?
Thanks for any suggestions.
Thatchh
- mjk1040
- Been thanked: 248 times
Re: 396 Aft waste tank hose access
- thatchh
- DanM
- Vessel Info: Carver 396
- Been thanked: 35 times
Kudos to Carver for using pvc on the long, under the flooring run. Using sanitation hose which have had to be snaked around would have been far move difficult and expensive.
As with many previous owners who think a boat is built the same as their house, mine used the heads indiscriminately without concern (or much water). If you apply due care, appropriate chemistry, lots of water for flushing and use of the marina’s head for #2 when reasonable, head hoses can last a very very long time without leaching. The 396 has two 36 gal holding tanks which is substantial capacity so extra water for flushing and regular weekend (or every other day when traveling) cleaning doesn’t have you rationing usage between pump outs. Best of luck on the project.
Carver 396
SugarSand Tango
- DanM
Carver 396
SugarSand Tango
- mjk1040
- thatchh
Thanks for the replies. I did not mean to give the impression that there was any odor from rigid PVC pipe. The odor is all in the flexible hoses as you suggested. Our boat use is often multiple days or multiple weeks most of which are spent at anchor. There are seldom marina restrooms to use. With four people on board, our water gets used up pretty fast, so extra flushing is not a good option. I will actually be installing a water maker this winter for next summer's trip from Seattle to Alaska which will help with the water consumption. Anyway, it turns out that removing the cabinet was quite easy, and there is a lovely access hole behind it. Carver even finished it and painted it so there's no sharp fiberglass to fight with. Now I can access those hose ends quite easily, as well as the vent connection. I should be able to replace all the hoses coming from the tank in short order.
Wish the rigid stuff was used more often. It should be anywhere waste will sit/remain in the line which is most of the run in electric and manual applications. With a Vacuflush system, the vacuum/suction side of the run from the toilet to the pump should always be empty but the pressure side may have waste in it depending on how the run is laid out. It should preferably be down hill from the pump to the tank so nothing sits in the line.
- DanM
Carver 396
SugarSand Tango
Users browsing this forum: Google Adsense [Bot] and 23 guests
