Unbelievable!!!
- sloopjonb
- Vessel Info: 1997 Carver 455
- Has thanked: 18 times
- Been thanked: 6 times
Unbelievable!!!
The only thing I can think to do is cut like a 4" hole on the side of the tub near the control valve to be able to reach the hose where is connects to the control valve, then add a watertight deck plate to seal it back up. Does anyone have any other ideas? - Sloopjonb
- Has thanked: 603 times
Re: Unbelievable!!!
I had the same happen with a wire once that disappeared, had to take lots apart to get the end back. Good luck with it.
- sloopjonb
Re: Unbelievable!!!
bud37 wrote:Source of the post The hole might actually be useful later on and the thing is those access ports are not so noticeable after a while ,....but for now, and you may have done this,... check in the salon for wall panels, access panels behind seat cushions etc, if there is a wall that is behind the shower cabinet.
Thanks! I have searched, and there's no way in from anywhere. I think you're right in that the access hole may prove useful in changing out the hose from the control valve. Hopefully, I'll place it well. Yikes!
Re: Unbelievable!!!
edit ... to add, is it possible to remove the fixture as a whole ?
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: Unbelievable!!!
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Re: Unbelievable!!!
Re: Unbelievable!!!
Is there a mirror close by that you can remove and cut a hole behind it that would then be covered by the mirror, or a cupboard that you can cut a hole in so the access port isn't so noticeable later?
Re: Unbelievable!!!
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Unbelievable!!!
- sloopjonb
Re: Unbelievable!!!
