Recommend me a TV/DVD for a boat...
- Jain
However if anyone can recommend me a TV with the following attributes, I'd be grateful...
Bulkhead mounting
Durable, not going to break on a boat
12V/240V options
Some kind of built in aerial or solution that does not involve the effort and expense of a masthead dish thing
Built in DVD or ideally Blu-Ray player (for Thomas and the Dinosaurs DVD)
Headphone port (so I don't need to listen to Ringo Starr's dulcet tones)
Compact...around the 20" mark should be fine
Thanks in advance!
- CYO Admin
- CYO Administrator
- Has thanked: 269 times
- Been thanked: 29 times
Re: Recommend me a TV/DVD for a boat...
Jain wrote:Source of the post Right, before I get a flaming for not just indulging in the lost art of conversation over a nice bottle of red instead
Yeah, we don't do that here. Welcome to the best boating forum on the www
I do have a combo unit in our aft cabin and we constantly have issues with playing some DVDs that will play fine on other units.
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
The Sony 6700 is nice and also has very good WiFi capabilities and built-in Netflix and cast capabilities - it's quite small and you can use it either horizontally or vertically.
There are some nice flat digital amplified antennas out there for about $25 you can mount almost anywhere - check Amazon or somewhere and see what you like. The omni-directional amped antennas work better on boats IMHO.
Most electronics today use 12 VDC base voltage with a switching power supply so you can run 120 or 240 - but check first and you may need a new plug.
Good luck and enjoy the show!
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- Been thanked: 491 times
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
Also mounted one of these behind the tv/bulkhead. Works well on the hook. Smart feature makes it work very well in a marina. Good hunting:
https://www.amazon.com/s?k=indoor+hd+an ... _sb_noss_1
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Again, depending on what boat you have, even the appliances (AC's, stove) may even be 120v. Even if you have a bigger boat with major appliances needing 240v, your outlets will still be 120v.
I suggest adding your boat model, year, length, to your profile. Cuts out a lot of the guess work.
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
As for a source, I have cable at the dock and I also use wifi and connect iPad to the TV to get Netflix. Some folks are using wifi and a streaming device and watch everything they need. A popular streaming device up here is a Red Rhino. Just not a great idea to use cell phone as a hot spot for watching television, uses a lot of data. I also have a digital antenna on the boat and that gives me 3 channels, if I was closer to a major centre I would probably get more. These antennas are not expensive.
