Removing wood plate
3807Guy
Topic author - Scurvy Dog
- Vessel Info: 1987 Carver 3807 Model.
Removing wood plate
- Ramsport47
- Has thanked: 72 times
- Been thanked: 59 times
Re: Removing wood plate
T-Merc 350 Mag MPI (300hp)
- Been thanked: 490 times
The plug will climb up the ramps of the screw.
Then go in the hole with a small screwdriver and clean any extra debris out.
Do what you have to do with the board, and upon reassembly, put some adhesive in the hole (just a little) and drive the plug lightly into the hole.
Then after the glue drives, take a clean sharp wood chisel and whittle away the excess.
It will look as new.
Users browsing this forum: Google Adsense [Bot] and 17 guests
