2001 Carver 444: survey says???
- Pete
- Vessel Info: 2001 Carver 444 diesels
- Has thanked: 56 times
- Been thanked: 15 times
The boat was deemed "above average" for its overall condition and the upgrades by the surveyor. Comps will be virtually impossible according to the surveyor, that is actually great news to hear.
Boat will need:
•new zincs all around.
•starboard rudder seal is weeping, time to replace.
•starboard trim tab minor repairs (couple of rivets are gone).
•waste pump discharge fitting needs replacement, badly corroded.
•needs bottom paint.
•one of the LED lights is inoperable in the fly bridge under the lid roof.
The best way to improve your memory is to do unforgettable things.
- Pete
Re: 2001 Carver 444: survey says???
Question: has anyone had to replace their "domestic" water pex lines? (it's not pex but is original water lines from Carver).
I am sure the surveyor spend at least a full day?
Enjoy the new boat!
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Are you also getting a mechanical survey?
Greg
- Pete
tomschauer wrote:Source of the post I don't believe I have ever seen a survey with that few notations, especially on a 19 year old boat. The boat must have been meticulously maintained.
Enjoy the new boat!
Thanks, most of the day was spent going through it. Each owner appears to have outdone the previous owner with care and upgrades. It shows. I am now soon to be owner #5.
- Pete
Tireless wrote:Source of the post That is awesome. Should give you some peace of mind. When I purchased mine it has minimal structural issues as well. Rudder seals, anodes and the other things mentioned are minor. I also had a couple of SS screw heads that broke off on the hinge plate on my starboard trim tab as well. I redrilled beside the old hole and reinstalled the 1 1/4 inch screws. Look on the Bennet trim tab web site and the specs for the screws are there. The trick is to drill the hole to the right size so you don't break the head off the new screws. I coated the new screws in 3M 5200 prior to threading them in.
Greg
I was considering it but with 575 hours and a recent clean oil analysis, I dont think it's necessary. Famous last words and hope it doesn't come back to bite me.
Also, although the surveyor talked about just "popping a few rivets back in", there is a bit of corrosion on the trim tabs. I feel like it would be best to replace both when the boat comes out for bottom paint, do it right. In addition, get the thrusters to "like new" condition. There was some corrosion there as well.
- Tireless
I had one done on mine for peace of mind. Oil analysis can tell you a lot. Some folks have a mechanical and still have problems after. Hard to predict even for the best mechanic. I had no major issues, just maintenance stuff and so for so good, touch wood. I replaced oil, all the filters and all other routine maintenance issues were addressed. Ran a Biocide for a while and started to use a fuel treatment called Stanadyne to improve performance and keep engines running clean.
As far as the mechanical survey it has always been recommended to me, but it is what you are comfortable with. You will love the boat, as I stated before we love ours.
Greg
- Pete
- Pete
- Tireless
