Diesel smell
- Pete
- Vessel Info: 2001 Carver 444 diesels
- Has thanked: 56 times
- Been thanked: 15 times
Diesel smell
I found a topic on this forum where people have had leaking aux tanks, etc. I did not see any leaks nor did the survey pick up any fuel leaks. When we did the sea trial I noticed a bit of the smell but I also dont know how long the boat was sitting closed up. After we drove it around, the only thing I smelled was residual exhaust, or so i thought.
How normal is this and does it really require a lot of cleaning? Curtains, carpets, bilge, etc.
Maybe I'm just being a little paranoid. The boat goes to the yard for survey punch list items on Monday. I will bring this up to them for further digging.
Any recommendations on what to tell them or what look at specifically? Thanks in advance!
The best way to improve your memory is to do unforgettable things.
Re: Diesel smell
Re: Diesel smell
It could be a current issue or a previous one. In my experience, diesel smell in the cabin takes a while to go away, especially if there's been a leak for an extended period. The odour permeates all soft goods on board and is a pain to get rid of but can be done with commercial ionizers. As stated though, find out first what's going on then take it from there.
Good luck and keep us posted.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Diesel smell
- Pete
Re: Diesel smell
Re: Diesel smell
- Pete
Re: Diesel smell
Viper wrote:Source of the post Fingers crossed for you that it's not a condition that will linger forever. On that note, are you sure it's a diesel smell and not permeated waste lines or stagnant water from the bilge or shower sump? I've had people confuse one with the other.
I dont know for sure, I am deferring to my broker to investigate further. My neighbors tend to stink up the air at times when they idle, but they are great neighbors to have.
- Has thanked: 603 times
Re: Diesel smell
... Like has been already said , a very , very small amount will produce a detectable odor....lets hope its a line or valve.- Pete
Re: Diesel smell
- Pete
Re: Diesel smell
Can anyone explain the fuel return lines from the engines to the tanks and fuel tank selector manifold plumbing? Or maybe is there a diagram? We fixed a few small leaks at the manifold but there is still fuel appearing in the cockpit lower bilge. No fuel in the engine compartment bilge. There is also a weeping from the starboard aux tank sending unit but I don't see that traveling down anywhere, probably about a cup of diesel in the bilge. I will dig through my manual but a good explanation of how its supposed to be used might point me in the right direction. Then there's the fuel transfer pump plumbing. Trying to get an understanding of what's supposed to take place. Thanks.
