Replacement parts for Widows/hatches 1994 Carver 350 Aft Cabin
- eswickberg
- Been thanked: 7 times
Im a new member and a new owner of a 1994 Carver 350 Aft Cabin. In respect to my windows and hatches I am trying to locate replacement parts for the following:
1) my 19" x 14" Aft Cabin Escape hatch (Vertical out to the Swim grid) has a crack in the lens. It's Bomar and I'm trying to determine the best way of replacing just the lens and the frame. I can't find the part number on it. Any advise would be greatly appreciated.
2) On the forum I've found some material relating to the sliding widows in the Aft Cabin, Aft Head and Salon windows. It's not clear to me where and from whom I might be able to get replacement parts for the seals and sliding trim seals (not certain of that's what they are called).
Any direction or indication as to how I can obtain product parts and availability would be greatly appreciated.
Eric
Re: Replacement parts for Widows/hatches 1994 Carver 350 Aft Cabin
If you contact Carver's Service/Parts Dept. and give them your hull number, they'll be able to give you their part numbers and supplier contact information including the supplier part number. Then contact the supplier. They windows and hardware might be Taylor Made though others supplied window hardware as well. They usually have some information etched on one of the corners of the glass. Hopefully some of the other guys have gone through this and can provide additional insight.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
you to push it in. To do all the salon and aft windows I used almost 400 ft.
- eswickberg
Thanks Again!
Eric
- eswickberg
Thanks for the information. Can you advised the process you used to replace these weatherstripping?
Eric
- Cooler
- Cooler
erhttp://www.seastarsolutions.com/product ... t-control/
Users browsing this forum: Google [Bot] and 48 guests
