3607 Upper Helm Access
- Winegrapewill
- Vessel Info: 1989 3607 Aft Cabin
- Has thanked: 3 times
Re: 3607 Upper Helm Access
Winegrapewill wrote:Source of the post The thought had crossed my mind to add a fuse block and eliminate all the inline stuff for radio, chart plotter, etc . . . It would make finding the right one alot easier.
What I am going to do (not done yet) is put a fuse block inside the cabinet just to the port side of the bridge helm. Run the large "bridge" +12V feed to that and use it to power all the accessories up there. Then it's easy to get to without pulling screws and the wiring would be very short. I mounted a radio/cd just above the doors to that cabinet too.
I did a similar thing in the lower helm. If you have a lower station, look in the projects forum. I put a sliding door in that panel below the lower helm and mounted a fuse block behind it (same model block I bought for the upper helm), so you can get to is easily, but it's "out of sight/out of mind" otherwise. There is one large (10ga?) +12v wire for the helm and for the bridge coming directly from separate breakers in the main panel.
https://www.bluesea.com/products/5026/ST_Blade_Fuse_Block_-_12_Circuits_with_Negative_Bus_and_Cover
- Been thanked: 491 times
Viper wrote:Source of the post I use these to do that guys. Don't use glass fuses anymore...
Those are the exact ones I have for both the upper and lower station.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
