Carver 466
- Happyours2
- Vessel Info: 2001 Carver 466 Hardtop with Volvo's
Re: Carver 466
Re: Carver 466
Re: Carver 466
Re: Carver 466
Midnightsun wrote:Source of the post Sounds like the jack stand was improperly placed plus a combo of soft ground under the keel which contributed to the failure. The jack stand is always positioned on the edge so it partially sits on the chine which has a heck of a lot more strength than anywhere inwards of the chine. Is there damage to the chine?
+1
I trust that if you buy the boat, you're not the one paying for the repair?
- Has thanked: 603 times
Re: Carver 466
Happyours2 wrote:Source of the post Hi, and thanks for responding, he said it could get fixed for around $5K. you could deflect the crack area with some moderate hand pressure which has me wondering if the Pasco warning about Carvers having thin hulls should have me walking away from the deal. The vessel reportedly settled on the stands while on the hard (soft) ground. One rudder post support which was glassed onto the hull popped as the boat settled downward apparently and the forward stand pad somehow tore into the hull.
There is always more, isn't there...
.......have someone that really knows boat structure have a good look at this before you continue, as there can be other damage hidden that may not show up for a while.....good luck man and be careful.I agree with the others, you can destroy any manufacturers boat with incompetent yard practices. Boats are designed to float not sit in parking lots or yards, that is why extra care must be taken.
Re: Carver 466
But it most likely can be repaired in 'like new' condition with a good shop.
- Happyours2
Re: Carver 466
Re: Carver 466
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: Carver 466
- Happyours2
Re: Carver 466
Lyndon670 wrote:Source of the post Where is this boat? I put an offer in on one that sounds like the same #of hours before I bougght my 506, and it failed the survey.
Lyndon, That is a sweet looking 506, wow! The 466 was at Marina Bay Quincy MA and I believe it was the same boat you had surveyed. Needless to say I guess my survey wasn't as thorough as yours because I swallowed the hook line and sinker. With $20+K of rudder and hull work and some pricy engine repairs we managed to get the boat up to Hampton NH and enjoy some wonderful sunsets before pulling the boat last month. I'm still dealing with some vibration issue portside and I'm curious to know what your survey may have uncovered? Thanks,
