89 3607 Aft Head Blower
- Winegrapewill
- Vessel Info: 1989 3607 Aft Cabin
- Has thanked: 3 times
With the switch on the main power panel on, when I go to the aft head and turn on the blower switch, the breaker in the main panel turns off. I get it, there is a short somewhere and I'm hoping it's the blower motor. The only problem is, with no blower motor noise, I don't know where it is.
The front head blower is in the bilge/engine room, so I look in there. Don't see anything obvious with the exception of a blower tube coming from the port side, going across to midline and hanging down from the floor (top of engine compt)
Is this the right tube or should I look elsewhere. Just where is that blower supposed to be?
Thanks for your help.
Re: 89 3607 Aft Head Blower
On my 355 its on the rear wall by the head. the blower is mounted to the back of the wall. To access it looked like I had to disassemble the wall panel, but found that removing the transom shower I could get to it. I guess my point is it may be in the cavity between the interior rear wall and the outside hull of the boat.
- Winegrapewill
- mjk1040
- Been thanked: 248 times
- Winegrapewill
Thanks for the help,
Will
- Winegrapewill
Thanks to for the help.
Stay healthy all.
My aft blower motor bearings wore out and did the same thing that you have... hit the switch and the breaker pops. I pulled the motor apart and cleaned and greased the bearings and got a few more years out of it before it went bad again - this time with a squealing sound.
Is that a mud daubber nest there? I found a few of those when I pop those access covers off in the spring. Glad to find them then rather than in the middle of the summer!
