How to remove wallpaper
Re: How to remove wallpaper
I have thought about doing the same thing but have not tackled that project so far. I had a few areas that were peeling up and I reglued them several years ago. Seems like that stuff shrinks over time so areas where it used to be held down with the trim now it doesn't reach that far anymore. With those areas popping up I was thinking it might all come off rather easily with the help of a putty knife but I had not tried that yet.
I'm also wondering what you're doing on the starboard side right next to the lower helm (if you have a lower helm). On mine the wall covering goes behind that area, and I was thinking you'd have to remove the helm to get it all. I guess you could just cut it at that point but then what would you do when installing the new stuff??
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
- StuartNewman
- Vessel Info: 1983 3607 aft cabin
- Has thanked: 6 times
km1125 wrote:Source of the post I have the same boat and wondering what you are considering to replace the wall covering?
km1125 On the starboard side I cut the wall vertically (where the vertical trim was) and was able to slide the 1/2 panel to the aft quite a bit. This exposed a lot of what was hiddenbehind the Helm console. I was able to remove more wallpaper and when it is recovered, I'll slide it back which will put the edge under the helm. I hope this will make it look better. The right edge will be under the trim.
This also has allowed me to access the back of the city water connection. I have been replacing the butyl waterlines on the port side where I can as the connections have been breaking. Now I can replace the starboard side behind the wall.
- SuzyQ
- Vessel Info: 1996 Carver Mariner 330
- Has thanked: 1 time
- Seaplane Steve
- Vessel Info: 1990 Carver 3608
- Has thanked: 4 times
- Been thanked: 2 times
Our 1990 looks like the wall covering has been painted and overall does not look bad. Between the ice maker and the lower helm there is an old marine radio that is not hooked to an antenna and an ice scoop holder that is covering up a bunch of holes.
Any thoughts on replacing a section of the wall and making it blend in?
May be easiest to just leave it.
- Has thanked: 602 times
