98 model 405 hot water heater
Re: 98 model 405 hot water heater
None of these tanks to my knowledge come with an anode yet they are offered as an option that can be added. I did add one plus a sediment filter to catch any particles that may erode from the sacrificial anode. A plastic sediment filter will not work as this is hot water so be careful in what you choose. Here is a link to the thread. viewtopic.php?f=11&t=3660&p=24627#p24627
- Serendipity
- Vessel Info: 1998 Carver 405
- Has thanked: 234 times
- Been thanked: 38 times
I am replacing some of the dry hard hoses with similar hoses meant for hot and cold potable water that I can reach. Probably will just leave the strainer alone since it looks clear inside and it was connected to the fresh water tank. It did have the stainless screen and gents, this 405 simply wasn't used the first 20 years of its life. 3 owners, 300 hours and I was told it was on a engine program where they simply started the engines every 2 weeks to a month, which may or may not have happened. Granted things can and do go wrong just sitting. It has been my experience with automobiles they go down faster, but as long as it will give me some hot water I am fine.
But the harbor master said the couple owners going back to 2005 rarely visited the boat because it was too much for them to take out.
I have spent over $15,000 updating the engines, bilges,blowers, fluid changes, detail, bottom painted, hell I even replaced the fuel injectors to make the trip home. Then I spent another $18,000 plus driving her home over 7 days. This included a 200 mile road trip where the top had to be disassembled to transport, then reassembled at a cost of $10,000.
Yet I haven't driven the boat since July 4th of last year in a warm climate where we have year round boating and I work all the time( my choice-self employed). This slow down has been great for me personally and we did grill out on the pier last weekend. Lol
So she sits on a fresh water lake in a covered concrete slip connected to all the necessities of life.
I have told my wife of 24 years, if we don't use the boat this summer, the 405 goes on the market next spring, although I have no clue what to ask for her after all the updates.
Just a gorgeous boat to let her sit anymore. I have 477/470 hours on her so time will tell and thanks to everyone for the information. Ya are the bomb.
- Been thanked: 654 times
- Serendipity
This is my first yacht other than my father having a 69 Chris Craft that was about 30 ft in length in 79. Not really any comparison compared to the 405 and I was 10. Lol
I probably bought more boat than I needed to start with or learn on.
Yes I am sure I got taken a few thousand by the repair shop in TX, however hindsight is 20/20. I have learned a lot and I do enjoy the boat when I use it. I simply need to use it more.
As always, thanks for your advice
- Erntster
- Vessel Info: 2000 Carver 350 Mariner
Twin 350 Mag Mercruiser Horizons - Location: Kaw Lake, Oklahoma
- Has thanked: 15 times
Hi Viper,
I'm having the same issue with my P/T valve on my Seaward S1100 water heater. I definitely want to replace it with one matching specs of the existing. In search for those specs, Seaward => Whale => Attwood now? From the water heater manual:
"Pressure temperature relief valve is factory installed. The pressure relief shall limit the
pressure to 127.5 PSI (879.3 KPA) minimum, 150 PSI (1034.2 KPA) maximum."
The Seaward part #73127 is shown as the temperature/pressure valve for all models. Haven't been able to find that original part number, only replacements that "fit All Seaward Water Heaters."
O.K...all the replacements (Defender Marine #75794, for example) show Maximum of 100 PSI, whereas the manual spec calls for 127.5 psi minimum and 150 psi max.
If these are truly Seaward replacements, is a part designed for 100 PSI maximum going to present a problem when Mfg spec was 127.5 PSI minimum?
Twin Mercruiser 350 MAG Horizons
"SunbErnt"
Kaw Lake, Oklahoma
These valves open 2 ways, 1 is pressure and personally I would prefer it open at 100psi on a boating application as opposed to 125psi. Reason being is our water lines tend to run about 40-50 psi. I would not want 127psi on these lines as a failure would most likely happen on the line before the valve would get a chance to open, 100psi is much safer so yes this valve is even better IMHO.
The white probe that sticks out a few inches is a temperature probe which will typically cause the valve to open around 210F or just a hair below boiling point if you prefer.
- Erntster
Thanks Hans
"SunbErnt"
Kaw Lake, Oklahoma
- Serendipity
If you own a 97 thru 2002 405 or 406. Then this should work for you.
So I received the new Whale S1100 11 gallon hot water heater from Hodges marine. This isn't a 30 minute job and would have taken me weeks regardless. I just need to know how things work, so I am methodical in how I repair stuff.
Aft cabin bed has to be completely disassembled I thought, but in hind sigh the bumpers may could have stayed on the bed probably.
So a marine hot water heater has a heat exchanger. I wasn't aware how this works, but I sure am now. Lol
You will also need a rear style hot water heat exchanger and they make a side and front version, so be careful here.
Fresh water holding tank has to come up and out to access the hot water heater. All hoses were stuck tight after 22 years. So I get the holding tank out and started working on the hot water heater.
Heat exchanger hoses are on the back side naturally. So I told myself, you need to get in the hole to look around and hook the hoses up naturally.
Yes at 6'4 and 195lbs, it wasn't designed for a man my size to get in there I surmise..
I liked to never got turned around and got my leg over the gas tank. No I didn't plan on going in, but I am the inquisitive type.
Once in I was going to remove the heat exchanger hoses while sitting directly in front of them. Who knew coolant would start spewing out once I took a hose off.
lol,, So now I am in coolant:banghead: I had a nice shirt on, so I removed it so my back could be right up next to the fiberglass. I really thought this out. Right guys
lolSo once I was inside, I started shooting pictures. It appears my exhaust tubes have been resealed within the past few years. No water leaks noted. I could get to the trim tabs connectors pretty easily and the swim ladder bolts were secure.i am better for seeing what I could access myself inside. I am attaching pictures from the hole underneath the stairs.
So I put everything back together, double clampped all hoses and check for leaks. Tightened a couple hoses on the front and tested. No Leaks
I have the best water pressure ever since I purchased the boat and no air in the lines now, so the faucets don't spray or hiss. New hot water heater is a major plus
Hopefully ya enjoy my stories, because I try to paint them as they happen or as I live them.
Happy boating ya
- Has thanked: 602 times
