Fresh water fill adapter
- dinomacc
- Vessel Info: 1988 Carver 3227 Convertible
Re: Fresh water fill adapter
- Been thanked: 654 times
- SplashyLady
- Captain
- Has thanked: 20 times
- Been thanked: 88 times
If your boat does not have this option, then my suggestion would be to simply put a t fitting on the pressure side of the fresh water pump located in front of the starboard engine, run some hose or pex back to the cubby, and put a hose fitting in. That way it looks like an original setup. You may want to add a fine screen or even a full water filter to the new supply line - some marinas don't have the best water quality... The best way to access the water pump is through the hatch inside the salon just forward of the sliding door.
Lake Norman, NC
Carver 3227 - "Splashy Lady"
- dinomacc
