1990 4207 aft cabin bilge pump
- martin65
- Vessel Info: 1990 4207 Carver
- Has thanked: 603 times
Re: 1990 4207 aft cabin bilge pump
I believe if you take the old one to a good marine store they can match up what you have there. One thing to remember ...unless you are the original owner and know, that pump could have been changed before so may not even be original to the boat.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
I wouldn't just get any pump that will fit. Getting the correct pump to fit the hose diameter is definitely important but keep in mind that not all pumps of the same capacity draw the same amount of current. You want to make sure that you don't draw more amperage through those supply wires than they're designed for as that can be dangerous. If that one has been operating for years at its rated load with no apparent ill affects on the wiring/circuit, then it's load is likely within spec for the wiring. Stick to the same amperage draw for the new one or slightly less to be safe but I wouldn't be going over the load rating of the current pump.
- martin65
This is probably your pump. https://www.westmarine.com/buy/rule-ind ... mp--215160
- martin65
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
