Fridge advice.
- Ityl
- Vessel Info: 2003 Carver 570 Voyager
Fridge advice.
I was wondering does it worth to hire someone to overhaul the system, when I get a fully functional -maybe more efficient(!) new built-in unit for $500?
Re: Fridge advice.
- Been thanked: 654 times
Re: Fridge advice.
Re: Fridge advice.
- Tireless
- Has thanked: 183 times
- Been thanked: 187 times
Re: Fridge advice.
A big advantage to the newer fridges over the old, is they run quieter and use less power when running 12 volt. The admiral found any new fridges we have purchased to hold more product and the are colder, with equates to colder beer.
This is a no brainer for me, go new and have problem free cold beer for years.
Greg
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
Re: Fridge advice.
I haven't priced dual voltage refrigerators so I don't know how much they actually do cost.
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
Re: Fridge advice.
“Escape Plan”
Murray, KY
Re: Fridge advice.
I suppose you can get around that by hooking up a small dedicated inverter and have it work off that permanently otherwise you have to unplug and plug between the two different sources or rig something up for remote switching. The inverter can't just be a cheapie, it should be a true sign wave if you want the compressor to last its expected lifetime. I had such a setup on a previous cabin cruiser, it worked fine but I eventually installed a full system unit when we had to keep turning on the generator every half hour for a couple of minutes to heat up baby formula in the microwave.
Some boats are factory equipped with 120 volt only units like Sub-Zero. Eventually an owner comes along in the boat's lifetime that prefers not running the generator all the time and pays to have a full system inverter installed which isn't cheap.
- RGrew176
Re: Fridge advice.
ColRon wrote:Source of the post Rick, the previous owner of our Santego had replaced the original Norcold fridge with a Magic Chief refrigerator from Home Depot or Lowe’s. Basically doing the same that your considering. The Adminal hated it. It really didn’t fit and the PO had bungee corded up the back so that it wouldn’t tip over and fall out. We also lost several full fridges of food. Seems the rural electric company here at our marina has trouble keeping electricity every time a rain storm comes through. We purchased a Nova Kool 7 cu ft with a freezer on the bottom to replace it. It was a perfect fit in the cabinet opening, actually switches to 12volt if a/c power is lost and most importantly the Admiral loves it. With shipping from Minnesota to KY to cost $1800 and worth every penny in the admiral’s opinion.
The fridge in my boat is the original. Not really sure how much longer it will run. While I am considering a regularr 120 volt unit I have not dropped the thought of getting a regular dual voltage marine refrigerator when the time comes. A lot of it will be determined by the timing of when the unit dies. This year I have budgeted to replace the 5 broken stanchions and possibly install the electronic ignition system. Hoping that nothing else needs attention or breaks down.
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: Fridge advice.
