Genset Puzzle
- denpooch
- Has thanked: 85 times
- Been thanked: 89 times
Genset Puzzle
I have a 2005 vintage Kohler 7.3 generator. Its a well maintained unit, new impellers every year, new carb 2 seasons ago. Heat exchanger boiled out with new carb installation. It was running great until.... it stopped running great.
The issue that I have is when at the dock or idling about she runs great. With a full load, its smooth sailing. Sometimes 'searches' a bit if the compressor on one of the a/c units turns off, but that seems par for the course.
The issue happens when I bring the boat to cruising speed. Running at 3400 rpm, doing around 17 knots, the unit decides to shut down. When this happens, I try to restart right away and it doesn't wanna cooperate. I'll go to the boat the following day, start it up and she'll run for hours.... at the dock.
The generator feeds off of the port gas tank which also supplies the port engine. I was thinking fuel pump, but a mechanic friend suggested that if it is a fuel pump issue, it would also have problems at the dock.
Any thoughts of solving this puzzle?
Thanks.
Re: Genset Puzzle
If you can run it all day long at slower hull speed, the above is what might be going on.
As long as you have over a quarter tank of fuel in that tank, it shouldn't be starving for fuel unless there is something else wrong or the tank pick up is at the front of the tank and the angle of the hull at that speed starves the pickup.
Re: Genset Puzzle
- ColRon
- Has thanked: 77 times
- Been thanked: 157 times
Re: Genset Puzzle
“Escape Plan”
Murray, KY
Re: Genset Puzzle
Just a couple ideas.
- denpooch
Re: Genset Puzzle
The 'intake' for Genset is a bottom facing, round plate about 6 inches in diameter with a bunch of small holes. When I painted the bottom, I cleaned out every one of the wholes so that I would get good flow.
Viper's idea of checking flow at the pump or strainer is near impossible, especially at speed, due to the position of strainer and especially the pump, which is somewhere near the rear of the Genset. Tomschauer, I do pay attention to the trim and besides the intake is pretty far aft. I does not see daylight under any circumstances.
I am not quite sure how to proceed with this one. Again, why now and not before????
- bobkirkbride
- Vessel Info: 2003 Carver 444
Re: Genset Puzzle
- denpooch
Re: Genset Puzzle
Re: Genset Puzzle
PS: check the vent line and fitting for that tank and make sure they're completely clear. To test if this has anything to do with it, remove the gas deck fitting cap while at that speed and see if the genny still shuts down. Only do this if you're sure you won't get any water splashing into the opening. Best to do it once you're on plane.
- Has thanked: 603 times
Re: Genset Puzzle
denpooch wrote:Source of the post I am not quite sure how to proceed with this one. Again, why now and not before????
Good question, why now.....considering that, has any work been done just before this started ? Perhaps you now have a restriction/marine life ....can you blow out the thru hull through the intake hose with a shop vac......check your hose fittings for loose clamps that may have been disturbed during any recent work.
The previous owner/owners may have never used the genny on plane, I know I don't, but if you have and there was no problem before now then the intake design is just fine, we all ( with the same boats ) would probably have the same design.
The gen running at the dock fully loaded will use the same water and fuel as other times, the gen has no idea how the boat is moving thru the water.
You really have to be sure why the gen is shutting down, could be as simple as vibration related electrical connection somewhere.
Just a few thoughts.....good luck with it, just try to be systematic in crossing things off the list, especially any recent work anywhere on the boat.
