water flow
- rjr
- Vessel Info: 440 MY
- Has thanked: 25 times
- Been thanked: 9 times
water flow
Thanx in advance.
Re: water flow
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: water flow
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
Re: water flow
Re: water flow
- Danpmart
- Vessel Info: 1997 355 AC
- Has thanked: 18 times
- Been thanked: 3 times
Re: water flow
Re: water flow
- Danpmart
Re: water flow
tomschauer wrote:Source of the post Whoa, that was a nasty tank!
I was seriously considering selling the boat....
- rjr
Re: water flow
Will try to respond to everyone:
midnightsun - yes -full.
cooler - increased flow rate to 5 gph. Have tried disconnect/reconnect. Have not run shore water and pump at same time.
buster - filter is clean.
viper - spec is for 5 gph. connections solid. pump is 12 volt.
danpmart - no nasty filter.
Re: water flow
I hope that increasing to a higher volume pump isn't overloading the wiring that might have been originally designed by factory to carry less of a load from the original pump. If that's the case, there will be a voltage drop and the pump won't run as it should. Will increase amperage though which might not be safe for the wiring if it's the wrong gauge for that circuit/new higher load.
