Leak from transom shield
Vincent3450
Vessel Info: 1988 Carver Santego
Postby Vincent3450 » June 1st, 2020, 7:46 pm
Hi, I have a 1987 Santego. Just put it in the water for season and after couple of days someone at marina notice it was taking on water and it had it taken out. Water did not reach near top of engine or batteries. Water leaking from transom shield. Will have it pulled and everything checked out. If transom rotting that may be it :-O
Hopefully just change gasket on transom. Boat needs some other work but basically sound and many new parts. Anyone with experience with this or has same boat or just want to say hello (and hope all goes ok). Thanks
ColRon
“Escape Plan”
Has thanked: 77 times
Been thanked: 157 times
Re: Leak from transom shield
Postby ColRon » June 1st, 2020, 8:14 pm
Is your Santego a 3067 with outdrives?
Ron
“Escape Plan”
Murray, KY
:usa:
Postby Viper » June 1st, 2020, 9:30 pm
I'm assuming this is a sterndrive application? If so, what brand? I know many came with Volvo DP but have seen Mercs too.
Vincent3450
Postby Vincent3450 » June 1st, 2020, 9:38 pm
ColRon wrote:Source of the post Is your Santego a 3067 with outdrives?
I/O sterndrives with mercruisers
Vincent3450
Postby Vincent3450 » June 1st, 2020, 9:40 pm
Viper wrote:Source of the post I'm assuming this is a sterndrive application? If so, what brand? I know many came with Volvo DP but have seen Mercs too.
Mercs
Postby Viper » June 1st, 2020, 10:10 pm
So there are a few places you could be taking on water. Could be from around the transom assembly which usually means a bad transom or through several areas in the transom assembly. On the inside of the transom, there are nuts all around the inner plate of the transom assembly. If you try to tighten those nuts and you actually can and get a couple of turns, chances are you're squeezing a saturated transom. Fingers crossed that's not the issue.
Some of the more common areas for water intrusion are; u-joint or shift cable bellows, gimbal ring upper swivel seal, gear lube fitting if applicable. If the leak is through the u-joint bellows, you want to get it out of the water asap or your u-joints will be sitting in water for a while which is not a good thing and can get pricey if the input shaft assembly has to be replaced due to corrosion.
Is this a salt water application?
ColRon
“Escape Plan”
Postby ColRon » June 2nd, 2020, 1:46 pm
Vincent3450, Viper is right on target. Check your baffles. Since you already out and on the hard, shouldn’t be a problem. Do you know when they were last changed? They are a service items. Would also be a good time service the drives while your at it, if they haven’t been serviced recently.
Ron
“Escape Plan”
Murray, KY
:usa:
Vincent3450
Postby Vincent3450 » June 2nd, 2020, 8:14 pm
I just had both port and starboard cables, gimbals and bellows, etc replaced and the upper and lower unit from the units which fit into the same port transom shield (sorry don't know exact terminology at moment (I am novice boater).
Bought last year. Was used for 30 years in freshwater on Lake Erie. Bought it mid summer last year, brought to NJ.
Postby bud37 » June 2nd, 2020, 8:36 pm
Do you know if there are muskrats in the marina....they can sink a boat in a hurry if they get at the rubber back there. Leave the drives down.
Second question...you said you just got this boat...did it come with a survey ??
Postby Midnightsun » June 2nd, 2020, 8:37 pm
Are they Bravo drives? If so the steering pin tends to corrode/pit and will need to be replaced as the seal can no longer do it's job. There are after market ones machined of stainless which corrects the issue for good and are actually 4 times cheaper than the carbon steel ones Merc offers. Been there done that. https://www.ebay.com/itm/Stainless-Stee ... SwLKNbtTqZ
