Flush ports
- Jimhanley01
- Vessel Info: 32 montego
Flush ports
Re: Flush ports
- Has thanked: 603 times
Re: Flush ports
Re: Flush ports
Re: Flush ports
Jimhanley01 wrote:Source of the post I tried to make up a flush port so I could winterize my engine. The hose is 1-1/4 ID with wire. I used standard plumbing fittings. The standard barb fitting has an OD over 1-3/16. The 1” fitting is too small. What am I doing wrong. There is no way to get the fitting into the hose even with heat to soften the rubber.
What type of fittings are you trying when you say standard plumbing fittings ? Bronze or plastic ? That could be the problem here.
