3227 stringers, etc
- James.smith
3227 stringers, etc
I’m going to look at an 88 3227 (with mercruisers) this Thursday and need some advice on what to look at as I’m still new in the boating community. I do plan to get a survey but have been burnt on a few carvers that have wet stringer or transom issues before and getting a survey each time is becoming costly. I love the 3227s because of the layouts and fit my budget pretty nicely. Any tips on what to look for/ common issues on them before I invest in another survey is greatly appreciated
- Cooler
- Has thanked: 68 times
- Been thanked: 413 times
Re: 3227 stringers, etc
I do know from experience, the older vintages, 1988 included need the wood inside the stringers to hold the engine mounts, and when the wood got wet the mounts would pull out along with a good chunk of the fiberglass.
So it kind of sucks that I had to yank an engine and replace part of the stringers on the starboard side.
There is no way a 1/4 or even 3/8 of glass could provide the support needed for the stringer system.
- Has thanked: 603 times
James.smith wrote:Source of the post Good afternoon!
Welcome to the forum.......I would check closely at the aft section of the main stringers....look at the joints there from the fore and aft stringer to the side to side.....just aft of the engines ....also the rudder and especially the strut support area. Which by the way is the same for any manufacturers boat.
Really, this is worth having a qualified surveyor check these areas. The savings alone is worth it if you miss something like this, it can cost from 10k to more than double that to repair.
It is also worthy to note that some of the newer versions use composite board as the stringer core in certain areas ( engine areas ) with the top hat elsewhere. It is obvious to see, as the top hat is much, much wider than the other.
