Clunking in prop shaft at low RPM
- Burnut
- Vessel Info: 1986 carver 36 Mariner
The boat is a Carver 36 gas engines.
- Has thanked: 474 times
Re: Clunking in prop shaft at low RPM
- Has thanked: 603 times
Burnut wrote:Source of the post Has anyone experienced a loud clunking in the prop shaft at low RPM. When adding just a little power it goes away and runs great. We greased the zerk fittings and that helped a little bit but it came back.
Welcome to the forum.... Th following is me assuming you have the remote v drive set up in your boat......
Is the noise coming from the joint that is between the engine and the v drive case, or the shaft from the v drive case to the prop. Check for slop/play in the joint/ shafts.
Is there grease and residue around the area of that joint ?
- mjk1040
- Been thanked: 248 times
