Window channel replacement
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
Re: Window channel replacement
- mjk1040
- Been thanked: 248 times
- eswickberg
- Been thanked: 7 times
- 89Convert
- Vessel Info: 2002 356 Carver
- Has thanked: 6 times
- Been thanked: 3 times
quickdecision wrote:Source of the post Just finished rebuilding the salon windows in a 3807. Bottle jack and 2 x 4"s allowed windows to be removed easily. Frames removed, cleaned, repainted. Re-bedded with butyl. Do not tighten screws all the way at first. Use 1/8" spacers. After about 2/3 weeks pull spacers and snug screws the rest of the way. Installed slick tape in the bottoms of the channels. This made the windows slide with one finger. DK hardware has the weather seals that seals the windows to the tracks. Make sure you clean the drain holes in the window frames. This is a major cause of leaks. Below are the companies that supplied the materials. Butyl can be bought from many sources. This is the material used to seal you car windshield in.
Ron
http://www.eplastics.com/slick_strips
http://www.dkhardware.com
Ron,
Did you order the 1/32" Thick X 1/2" Wide slick tape and did that fit into the channel or did you need to trim it's width? Thanks!
- bashy11
- Vessel Info: 1992 Carver Aft Cabin
