Carver 4207 with 454's fuel consumption
BoatinBob
Vessel Info: Looking at 4207's
Postby BoatinBob » August 4th, 2020, 6:06 pm
Would anyone have fuel consumption specs for a 4207? i.e. mpg at different rpm's and speeds?
Thanks in advance, I've searched everywhere with little luck, so I thought I would ask!
Thank you!
Been thanked: 491 times
Re: Carver 4207 with 454's fuel consumption
Postby waybomb » August 4th, 2020, 7:02 pm
I don't remember what our 4207 burned, but let me tell you that you should buy a trim tab indicator and a very good fuel flow meter. You'd be surprised how a couple degrees of tab and sight changes in throttle can increase your fuel efficiency..
I was very surprised.
Johnnykey
Vessel Info: 98' Carver 405
Has thanked: 27 times
Been thanked: 19 times
Postby Johnnykey » August 4th, 2020, 7:38 pm
https://www.boat-fuel-economy.com/mercu ... us-gallons
Very accurate. Your MPG will depend on your speed for given RPM. I'm guessing that your 4207 has quadrajets. You can tune a quadrajet to get better GPH than an MPI motor. But You wont have the advantage of knock sensors.
Postby tomschauer » August 4th, 2020, 7:50 pm
Just to clarify, you wont get miles to gallon with gas engines in that boat. Its gallons to the mile :-D
Been thanked: 470 times
Postby RGrew176 » August 4th, 2020, 8:15 pm
Or as I get on my 81 3007 an average of .86 miles per gallon.
Postby tomschauer » August 4th, 2020, 8:34 pm
Or is that 1.14 gallons to the mile? :-P
buster53
Vessel Info: 2001, Carver 356
Has thanked: 10 times
Been thanked: 285 times
Postby buster53 » August 4th, 2020, 8:45 pm
I used to have a 3807 with Merc 454's. What a gas hog. I can't imagine a 4207 with gas engines.
At plane, we got less than 1/2 mpg. That's why we almost always ran at hull speed, about 7.5 knots. At that speed, we got about a mile per gallon. Big difference. Unless you want a permanent spot at the fuel dock, run hull speed. Your wallet will thank you.
Postby tomschauer » August 4th, 2020, 8:59 pm
Yep, that's a lot of boat for 7.4's. They will push it ok, but don't be in a hurry.
BoatinBob
Postby BoatinBob » August 4th, 2020, 10:26 pm
Thanks for all the input, cruising at hull speed sounds like the way to go, and only open it up when the beer cooler runs empty lol.
Just trying to get a rough idea, and I think I got it!!
I appreciate all the input!
kamakazerc
Vessel Info: proud new owners of a 1988 3607 aft cabin,as of august 2018, and still have at this time our 1980 mariner 2896
Has thanked: 3 times
Been thanked: 8 times
Postby kamakazerc » August 6th, 2020, 11:33 am
Hi, I have an 88 , 3607. I haven't bought these yet, but there on my list to perchase soon. I had fuel flow meters on my last boat ( Carver 2897) and loved them.
Saved me a lot of fuel!
These are even better with the app supplied.
https://www.interactio.co/?gclid=Cj0KCQ ... TfEALw_wcB
And , no, I'm not affiliated with interactio in any way.
Just did my research, and want them on my boat soon!
Regards.... Mike from , Au Gres MI
