Close to being a new 310 Santego owner
- Capn Crunch
- Vessel Info: 1995 Carver Santego 310
Crusader 350XL injected, Hurth Inboard - Location: On the Mighty Columbia River in the Pacific Northwest
- Has thanked: 87 times
- Been thanked: 7 times
Been awhile since visiting as I solved some issues on my own, some with a mobile mechanic who's hit and miss with his appointments, and still have a steady supply of "round to it" wooden nickels in my possession, much to the Admiral's dismay!
Our Montego has been doing well for us when there's no wind, a booger to return to the slip in a breeze.
All this is leading up to today and why I'm posting in this thread - We just put a deposit on a '95 310 Santego today! Sea trial tomorrow @ 5pm PST!!!!
Any valuable insider issues I should check out while during the trial? Is inboard's, haven't had a look yet, did Carver do V-drive, or direct? Still Borg/Warner - or did they switch vendors?
Also, running into a HIN issue - at some point the HIN was changed from a Carver to a "homemade" HIN, presumably cuz original HIN didn't conform to new as of 1984 standards? Make sense to anyone here?
Thanks for any input/advice!!
- Has thanked: 603 times
Re: Close to being a new 310 Santego owner
Capn Crunch wrote:Source of the post Also, running into a HIN issue - at some point the HIN was changed from a Carver to a "homemade" HIN, presumably cuz original HIN didn't conform to new as of 1984 standards? Make sense to anyone here?
I would call Carver and check the HIN......or are you saying the boat is registered/licensed with homemade attached to the hull id number that is actually on the boat hull, or they changed the original number itself.
That 310 came with either twin V drives or twin stern drives.
- buster53
- Has thanked: 10 times
- Been thanked: 285 times
- Capn Crunch
So after a conversation with Carver it became apparent that the probable issue was a typo at some point in the process (last 4 of HIN originally was i495, in 2013? ish - when current owner purchased - number inadvertently was reported to WA DOL as 1495) which prompted a call directly to the state.
That call was very rewarding as the young lady (she must be young right? She's still working
went through the title in detail (not sharing a complete history for privacy reasons she said) and title is clean, no liens and no salvage/stolen or any other notes or record. She read notes of other title officers and said in 2017 there was a change federally how HIN numbers must look (1st digit of last 4 was out of line, go figure) and at that time the titling officer made the change noting the previously reported HIN.TLDR: Title is clean, with no liens and no record of salvage or otherwise.
- Capn Crunch
tomschauer wrote:Source of the post The HIN is attached to the boat when manufactured and should never change. the last two digits (95) is the model year of the boat.
I would never accuse WA state to use logic when dealing with anything they can make a buck on. All I have to go by (unless someone here knows of another way to source it) is what the state told me this morning - number change was done/required by the state, no liens, no salvage reports, nothing. Title notes actual HIN in comments, albeit with the typo. Probably wouldn't hurt to call back and reask with the idea that title check websites refer the new number as "homemade".
I'll update again if there's a hint of a problem... in the meantime looking forward to a successful sea trial!
- Capn Crunch
https://carveryachts.blob.core.windows. ... _94_v1.pdf
- Capn Crunch
bud37 wrote:Source of the post Here is one for a 94....2610/2897....310 Santego
Wow!!! thank you very much!!! How did you source that?
