Boat polish or paint?
Topic author
jaybla812
Vessel Info: 1989 Carver Monterey Cabin Cruiser
Postby jaybla812 » May 27th, 2015, 1:00 pm
Ahoy:
I own a 1989 Carver Monterey cabin cruiser.
The last couple of years the shine has faded more and more especially on the long blue strip along the sides.
I have tried several polishes and recently a rubbing compound with no luck. Last year I took it to an auto body shop, which helped for a while but still faded after a few weeks on the water.
I just can't get the color to "pop" like it used to.
All suggestions would be appreciated.
Been thanked: 491 times
Re: Boat polish or paint?
Postby waybomb » May 27th, 2015, 8:59 pm
Need to go to a marina that knows how to do this.
They will wet sand with a 600 and then maybe a 2000, then do a 3m perfect-it #1 (or similar heavy oxidation compound) with a Makita-type machine buffer, then #2, then a fine polish, and then a wax.
Or a similar procedure. My 36 went 11 years out in the weather untreated and unused and was severely chalked. I used 2000 wet sand, then Perfectit 1, 2, then 3m marine heavy oxidation restorer, and then a swirl remover, and finally covered it with a polymer. Looks like new. Many hours with that Makita buffing machine.
BobWaz
Vessel Info: 1995 Carver 380 Santego 330 HP Crusaders
Postby BobWaz » May 28th, 2015, 8:56 pm
There is a product called Vert Glass. The process is in I believe 4 steps. It is labor intense. If you specifically follow the directions, it will give great results. I had used this on the black on my Mastercraft.
Ramsport47
Been thanked: 59 times
Postby Ramsport47 » May 29th, 2015, 6:37 am
DO NOT USE VERT GLASS!!!!! It will start peeling off regardless if you do it properly or not!
Kenny
T-Merc 350 Mag MPI (300hp)
BobWaz
Postby BobWaz » May 29th, 2015, 8:18 am
Vert Glass....As I said, specifically follow instructions. I re did my Mastercraft about 5 years later, then sold it. Had 2 friends that used it. One came out horrible, the other great and loves it.
After Taxes
Vessel Info: 'After Taxes'
2004 Carver Mariner 360
Lake Simcoe & Georgian Bay,
Ontario, Canada
Has thanked: 6 times
Been thanked: 17 times
Postby After Taxes » June 9th, 2015, 11:10 am
Hi.
Highly recommend you do the wet sand method as Waybomb suggested. I did that to a very sun-dulled 1989 Doral Montecello, but it looked showroom new afterwards. When I replaced the top, and with the hull shining, so many people asked me if it was a new boat. After this method, it was extremely easy to keep up appearances with normal waxing.
Go the wet sand method. You will be absolutely satisfied!
Respectfully,
Steve
MerCruiser MX 6.2
Lake Simcoe, Ontario
Users browsing this forum: No registered users and 43 guests
