Vacuflush
PAULDOC
Vessel Info: Riviera 28 1983 with twin Crusaders
Vacuflush
Postby PAULDOC » August 19th, 2020, 11:03 am
Anyone know where the duck bill valves are located on my 1983 2807
Also where can I get shop manuals
Been thanked: 248 times
Re: Vacuflush
Postby mjk1040 » August 19th, 2020, 1:48 pm
Well depending on what model you have, you could have 2 or 4 duck bill valves. Most generally its 4 and they are located in the lines before and after the vacuum pump itself. A simple google of your unit will most likely find you a parts diagram and part numbers because there can be few different size duck bills.
PAULDOC
Re: Vacuflush
Postby PAULDOC » August 19th, 2020, 5:33 pm
tonyiiiafl
Has thanked: 601 times
Been thanked: 193 times
Re: Vacuflush
Postby tonyiiiafl » August 20th, 2020, 7:14 pm
I was surprised to see my forward head on my 390 has 2. I am going to compare to the aft unit. Both units have beeen great. However, lately the forward one has been pumping quite often. I changed the duck bills, and found a small hole in the piping. I think I need to replace some of that piping. I may do a rebuild on the pump also.
tonyiiiafl
Re: Vacuflush
tonyiiiafl
Re: Vacuflush
Postby tonyiiiafl » August 22nd, 2020, 12:24 pm
I checked the aft Vacuflush unit and it has the adaptors. It appears the po removed the adaptors on the forward unit for whatever reason. Ordering the adaptors and a bellows. Stay tuned.
Re: Vacuflush
Postby g36 » August 22nd, 2020, 7:03 pm
not bad to maintain depending on access to it
