Carver 355 Aft Cabin -,windows leak. Looking for info to repair or replace
Gerry Johnson
Vessel Info: 1998 Carver 355 Aft Cabin
Postby Gerry Johnson » August 21st, 2020, 3:29 pm
I have a 98 Carver 355 Aft Cabin. The rear and side windows leak and have mould in the channels. Looking for help with restoration or obtaining replacements!
anyone familiar with this problem?
Gerry
Re: Carver 355 Aft Cabin -,windows leak. Looking for info to repair or replace
Postby g36 » August 22nd, 2020, 8:58 pm
I believe about 98 is when carver changed window designs on the aft cabins boats So do you have large sliding windows in the salon or do you have fixed salon windows with a small opening window?
Postby bud37 » August 23rd, 2020, 10:56 am
Gerry Johnson wrote:Source of the post I have a 98 Carver 355 Aft Cabin. The rear and side windows leak and have mould in the channels. Looking for help with restoration or obtaining replacements!
Gerry
Welcome to the forum.....before going further, clean the window channels real well, ( small brushes etc ), many times that will stop the leaks because the small drains were plugged.....good luck with your boat....
Been thanked: 248 times
Postby mjk1040 » August 23rd, 2020, 11:49 am
Start with cleaning tracks out as Bud37 says. Aft window pile I pulled out and replaced with stick on pile as the original is plastic backed and can only be replaced 2 ways, take the window out and apart or you'll have to grind a notch out of the original track big enough to feed the new plastic back pile into the channels. SAme with the side windows! :beergood:
Users browsing this forum: No registered users and 42 guests
