3207 Cruise Speed
emunstar
Vessel Info: 1991 Carver 3207 Aft Cabin
Has thanked: 4 times
3207 Cruise Speed
Postby emunstar » August 22nd, 2020, 1:49 am
Calling all 3207 owners.
What speed do you cruise at? I’ve got a 1991 with Crusader 270’s. I’ve been going wide open throttle to get in plane and then pulling back the throttle to around 16 mph.
What do you like and what has given you decent fuel economy?
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Re: 3207 Cruise Speed
Postby Cooler » August 22nd, 2020, 9:35 am
Mariner 330 owner here. I have 5.7XL Crusaders. I cruise at 19mph, 3000RPM. Gas burn at 15gph. Seems to be the sweet spot for cruising in terms of performance, hull efficiency, and ride. I do not go WOT, but bring the hull to plane gradually, and then trim using tabs. If I go to 3400 RPM, I am at 23mph, and furl burn at 24gph. 8-) er
Cooler By The Lake
Tireless
Volvo Penta D6 370 HP
Has thanked: 183 times
Been thanked: 187 times
Postby Tireless » August 23rd, 2020, 8:06 pm
I ran my 1986 3207 with 5.7 Mers’s and I would run it at 3200 rpm on plane. If you run it hirer the 4 barrels will kick in and almost double your fuel consumption. 3200 rpm would give me about 20-21 mph from what I recall with a proper trim tab setting. Great running boats and they can handle the heavy water, for sure.
Greg
