MarinAire AC Unit Swap
Postby Midnightsun » August 23rd, 2020, 2:48 pm
Never did post a pic of the MarinAire unit swap. Out with the old, in with the new. :-D Took me about 4hrs to do with lots of thought and prep work prior. Original Marine Air was noisy, inefficient and just not as cold as the newer units out there, MarinAire took care of all those issues.
Aj325
Vessel Info: 1996 325 Aft Cabin
350 XL's
Has thanked: 4 times
Been thanked: 2 times
Re: MarinAire AC Unit Swap
Postby Aj325 » August 23rd, 2020, 5:02 pm
Good to know replacement of the unit is not a terrible task! What was the BTU rating on the old unit?
Postby Midnightsun » August 23rd, 2020, 5:45 pm
Old was 16,000 same as new however it feels like I have a 20,000 and it sounds like I have a only air blowing. :-D
I always tend to over think stuff which is not a bad thing. Used the rear drain port of the new unit to allow water to run easily when a slope occurs with throttle application. Also leaned the unit slightly rearward so water runs out on its own as opposed to stagnating in the pan when at dock. Elevated the entire unit a good 4 1/2" to allow for easier access and hose connection slope. Had to reduce the existing duct by adding a reverse reducer to the new unit fron 6 to 7". In the end though, the outcome is much better than what Carver installed with unfortunately not too much thought behind it.
Last edited by Midnightsun on August 23rd, 2020, 7:05 pm, edited 2 times in total.
Postby g36 » August 23rd, 2020, 5:48 pm
nothing like cold air.
SplashyLady
Has thanked: 20 times
Been thanked: 88 times
Postby SplashyLady » August 24th, 2020, 4:00 pm
:down: :worthy:
Captain John
Lake Norman, NC
Carver 3227 - "Splashy Lady"
Postby km1125 » August 25th, 2020, 10:59 am
Is that on a slide-out pan, or is there more cabinetry that covers it up in the position it's in?
Postby Midnightsun » August 25th, 2020, 11:19 am
Fixed pan, there’s a notch in back of the sofa. ;-)
