new owner of 89 Montego 2557
- Canuck Carver
- Vessel Info: 1989 2557 Montego Twin 470s
Cheers,
Tomi
- Been thanked: 490 times
Re: new owner of 89 Montego 2557
- Beufort
- Vessel Info: 86’ montego 26.
- Has thanked: 4 times
- Been thanked: 5 times
- Canuck Carver
I've wrenched on cars since i was 10 or so with dad who is an auto mechanic AND thankfully a marine mechanic from the old country. He grew up working on Volvo stuff years before we moved to Canada. Quite interested in renovating this Montego to what we want, but overall it is in pretty decent shape.
Got a great deal on it, but only because it comes with twin Merc 3.7l 4 bangers. everything I have read on these says run, run, as fast as you can...but they run great, and the water test was great. Hoping to get a couple months of cruising in before putting it into the pole barn for a family reno project.
Are there any other owners here with 3.7s?
T.
- RGrew176
- Has thanked: 72 times
- Been thanked: 470 times
- Canuck Carver
With those 3.7's, run, run run them until they die. Then replace them with 4.3's.
Not bad engines, parts are expensive and hard to come by. They are a mercury cast aluminum block with a ford 460 cast iron head. Also the same bore and pistons as a 460 but different stroke. Keep good clean oil in them at all times. A good idea is to pull the rocker covers and check the torque on the head bolts. Leaking head gaskets were the Achilles heal for these. A small coolant leak over a long time causes the cylinder bores to go out of round.
I had a 2757 with the 190hp 3.7 LX 4bbl engines and alpha drives. They ran pretty good, but a little lacking on the low end. Kind of surprising for a big bore 4 cylinder.
- Makis96
- Vessel Info: 1989 Carver Montego 2557
- Has thanked: 1 time
- pepmyster
8.1 Volvo Penta
- Has thanked: 492 times
- Been thanked: 210 times
Users browsing this forum: No registered users and 72 guests
