Kohler generator 10 ..diesel
winedown
Vessel Info: 2004 396 Carver motor yacht
Has thanked: 17 times
Been thanked: 3 times
Postby winedown » September 21st, 2020, 4:19 pm
Generator won't start...When we were at the dock, we started genny prior to going out on the water & it started & ran fine...Once out on the hook later that night, genny wouldn't start..We get a sort of humming noise when pressing switch..We have tried to start from the switch on the unit with same result..We have replaced the battery..Oil, coolant & water are fine..We replaced the impeller last year as it started but switched off after 10 mins or so...Over heating is not the problem this year...It just won't even start...I have read a lot of your posts..Circuit boards, solenoids, breaker, fuses ??..Thoughts ??
Italy
KeithS
Vessel Info: 2005 38SS
Been thanked: 23 times
Re: Kohler generator 10 ..diesel
Postby KeithS » September 21st, 2020, 6:16 pm
Easier to give helpful advice if you post the model number. I'm guessing 10EOZD?
Postby tomschauer » September 21st, 2020, 11:07 pm
If its just a humming noise, could it be the starter not engaging?
winedown
Postby winedown » September 23rd, 2020, 6:52 am
I will check the exact model # on Friday...We were thinking maybe starter, solenoid , circuit board?..It doesn't start from the panel switch or the switch on the unit...Thx for your replies..
edw
Vessel Info: 1983 3607
Has thanked: 2 times
Been thanked: 4 times
Postby edw » September 25th, 2020, 2:34 am
Sounds like starter bendix quit. It is the thingy that moves into the engine when starting to connect starter when starting, then retracts when starter disengaged.
Some starters have bendix as integral part, other have replaceable bendix.
Let us know...might help someone else.
winedown
Postby winedown » September 25th, 2020, 9:38 am
We have a tech working on it right now...He fiddled with a connection & it started, but now it doesn't..He is reviewing the wiring diagram from the manual & checking our wiring??..
winedown
Postby winedown » September 25th, 2020, 11:01 am
Genny has started !!..Tech replaced a relay in the black box on top of genny & a connector to the starter..Trouble shooting lead towards circuit board but our tech did not think that was the problem and he was right !!..Hope this helps others with similar problems..Thx everyone for your advice..
Italy
KeithS
Postby KeithS » September 25th, 2020, 1:11 pm
From your description you have a 10EOZ. On that model the circuit board sends a signal to the K20 relay (black square Bosch type) inside the controller. That sends the signal to the starter. The humming sound you heard was probably the electric fuel pump which you can't normally hear when the engine is cranking. Glad to see an easy fix! If it was the starter, that usually is not accessible without unbolting the generator and moving.
