Out of the water for another year
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
Re: Out of the water for another year
The Volvo diesels are a little more complex as they have dual oil filters, an air filter, a primary fuel filter and a crankcase breather filter. Then there are the secondary Racor filters and separators for each engine. I normally do all mechanical on 1 day close to haul out and leave the pink stuff after haul out since engines, genset and AC need pink as well as potable water system.
- rjr
- Vessel Info: 440 MY
- Has thanked: 25 times
- Been thanked: 9 times
Viper wrote:Source of the post In case you're describing a problem or looking for parts re an issue in the future, it's the other way around Hans, the Racors are the primaries and the on-board engine filter is the secondary.
Funny you mention that since when I was typing I was questioning which was which. Makes sense since the fuel enters the Racors first (primary) and then (secondary) the engine mounted filter.
- 89Convert
- Vessel Info: 2002 356 Carver
- Has thanked: 6 times
- Been thanked: 3 times
- phatboat
- Vessel Info: 1985 3607
$4,000 for unheated and only $1,800 to keep it outside. There is no way I am paying 8k to keep a 35 y/o 3607 cozy.- Phrancus
- Has thanked: 16 times
- Been thanked: 136 times
- Contact:
Just to do a few small local trips to investigate, test, try and probably lengthen the list of ToDo's over winter. End of next month she's coming out again and put in a workshop to tick off that ToDo list over winter.
Past winters got less and less frost, no snow at all last year. Perhaps next year leave her in with some form of heating plus winterizing.
Oh, we're in Europe, 51°51'58.8"N 5°49'15.7"E
Return to “Boating & Cruising Lifesyle”
Users browsing this forum: No registered users and 4 guests
