Replacement water tank
- tonyiiiafl
- Has thanked: 601 times
- Been thanked: 193 times
- Been thanked: 654 times
Re: Replacement water tank
- tonyiiiafl
My 3607 has 120 g of potable water and it takes us quite a bit of time to use. Mine are poly tanks. What is your tank made of? If it's any metal I'd avoid keeping chlorine in there. OK for shocking it in the spring, but it's corrosive to metal long term.
- tonyiiiafl
My boat came stock with two tanks, but they are paralleled so they are essentially one tank. Each individual tank is 60gal. There is a simple "T" that's on the large 1.5" fill line that goes to both tanks. The "draw" line going to the pump just comes from one tank and the two tanks equalize level though the 1.5" fill connection. The vents are combined with a "T" fitting and run to one overboard vent.
- tonyiiiafl
- Has thanked: 603 times
tonyiiiafl wrote:Source of the post I have been thinking about the added 240 pounds the new tank would add to the stern. I have to look into the plumbing 2 tanks together thing. Thank you.
Tony....is your current tank on the boat centreline now ?
- tonyiiiafl
