Moss in window tracks
Topic author
Wauchopia
Vessel Info: 1990 Carver 3807 Just big enough for a family of 5 including 3 boys. You DEFINATELY need a full size fridge if you're cruising with these fellas.
Postby Wauchopia » May 17th, 2015, 9:09 am
I have a new to me 3807 with moss growing in the tracks of all of the sliding windows. I had the same problem on my 3207. The problem with both models is removing the glass to clean the tracks. Any idea how to get the glass out or how to clean the tracks with the glass in?
michelml54
Vessel Info: carver 325 motor yacht 1998
Re: Moss in window tracks
Postby michelml54 » June 5th, 2015, 12:58 pm
I do have the same problem on my 325 motoryacht 1998
is there someone having an answer please
Been thanked: 491 times
Postby waybomb » June 5th, 2015, 6:09 pm
I just hose it off from above with the city water pressure hose. It eventually goes away with enough flushing.
The moss is probably growing because the drain slots are completely or partially plugged. No water/no growth.
Lotsa of flooding with the hose cleans the slots and the slides out.
After Taxes
Vessel Info: 'After Taxes'
2004 Carver Mariner 360
Lake Simcoe & Georgian Bay,
Ontario, Canada
Has thanked: 6 times
Been thanked: 17 times
Postby After Taxes » June 27th, 2015, 9:06 am
It could be airborne organic material that must be killed with a bleach solution, to prevent it from growing back. Much like mold, it cannot simply be cleaned or hosed off. On a similar topic, the black spots on fibreglass, particularly in the diamond or no-skid patterns, is mold, and must be killed with bleach.
MerCruiser MX 6.2
Lake Simcoe, Ontario
Postby waybomb » June 27th, 2015, 6:36 pm
I have never used bleach on any of my vessels.
I would not suggest it at all.
But if you do I would soak a towel with it and rub and then houe it off for a long time.
After Taxes
Ontario, Canada
Postby After Taxes » June 27th, 2015, 7:40 pm
Re bleach, Have you had bad experiences with it, for boat use? I have had success with a bleach/water solution on no-skid mold. My neighbour has also successfully used a weak bleach solution on his sunbrella to attack mold, and he said there were no negative effects from doing so.
thank you,
Steve
MerCruiser MX 6.2
michelml54
Postby michelml54 » May 2nd, 2016, 3:14 pm
Wauchopia wrote:Source of the post I have a new to me 3807 with moss growing in the tracks of all of the sliding windows. I had the same problem on my 3207. The problem with both models is removing the glass to clean the tracks. Any idea how to get the glass out or how to clean the tracks with the glass in?
i had the same problem. I used a pressure machine like the one you used sometimes for your car and it did the job very well
Grafunkus
Vessel Info: 1982 33' Carver Mariner
1985 3607 Carver Aft Cabin
Has thanked: 63 times
Been thanked: 32 times
Postby Grafunkus » May 14th, 2016, 10:20 am
I used a popcicle stick to scrape it out then vacuumed it up.
Users browsing this forum: Majestic-12 [Bot] and 43 guests
