What do you use the water for?
SunsetSteve
Vessel Info: 83 Carver Riviera 28
76 Albin 25 (outgoing)
Has thanked: 30 times
Been thanked: 19 times
Postby SunsetSteve » November 3rd, 2020, 7:56 pm
Our new-to-us Riviera holds 80 gallons (300 litres) of fresh water, and 160 gallons (600 litres) of fuel. I assume we get similar range as other dual-engine Carvers with this fuel. This kind of boating is new to us - our experience with the Albin 25 was with very economical fuel consumption (36 hp diesel, 7 kts) and bottled water.
My questions:
1. what do you use the water for? I am thinking - washing up, showers, cooking . . . but drinking? Is dockside water supply and 40 year old holding tanks/tubing to be trusted for drinking unboiled water? (not by my wife, no way, whatever your answer might be lol) Or do you bring a few jugs aboard strictly for drinking? What is normal?
2. What sore of range to expect with conservative speeds with this sort of gas storage? Twin 220s btw.
Just wondering what to expect when we finally launch in the spring.
Re: What do you use the water for?
Postby bud37 » November 3rd, 2020, 8:16 pm
We always brought bottled water....you can clean everything and install filters and uv light system which some have done.
Here is a GPH calculator, just plug in your stuff and it will be close. Hull speed for you will be no more that 6 knots ( approx 1500 to 1600 rpm) and on plane cruise probably around 2800 to 3100 Rpm from what I remember ( had a boat with the exact same hull as yours). Just calculate your range based on the numbers you come up with.
https://www.boat-fuel-economy.com/fuel- ... calculator
Postby tomschauer » November 3rd, 2020, 10:18 pm
The water is for dish washing, people washing, cooking, etc. I clean and sanitize our fresh water system, but do not use it for drinking water. The only reason is because of the quality, or lack thereof, of the dockside water used to fill the tank.
We always have bottled water for drinking.
Your twin gas Carver will be a bit of a "shock" with the fuel burn, but you will get from A to B in less than 1/3 time if you desire.
Postby km1125 » November 4th, 2020, 12:59 pm
We've definitely used our potable tank for drinking and cooking water, as well as regular washing and showers. I replaced all the ~38 year old lines with PEX a couple decades ago and make sure we sanitize the system every spring. We do also have bottle water on board too, for the convenience of having it cold (in the fridge or cooler) and carrying around.
At the dock we are usually connected directly to city water, so the potable tank is used only away from port.
You will go through a lot more fuel with gas than the old diesel, but you will now have the option to get on plane and get places faster if you wish.
Postby Midnightsun » November 4th, 2020, 2:58 pm
Drink it all the time however the water from the marina is potable in my case as well as all marinas in my area that I know of. I do properly sanitize the tank and lines every spring and run a dual cartridge filtration system. Been drinking on board water in all my boats for over 20 years and never an issue.
Cooler
Home port: Menominee, MI
Has thanked: 68 times
Been thanked: 413 times
Postby Cooler » November 5th, 2020, 10:47 am
Fir what it is worth, that link Bud provided is dead on with my fuel consumption. Your consumption may be a little more because that Riv is a heavy boat. I never consume water stored in holding tank. I do consume water when hooked up to dock, but would run a gallon through first, and always use a marine designed water hose as equipment. That hose is made with an inner layer that resists bacteria and mold/mildew. That Riv is a really nice boat for comfort and room! 8-) er
Cooler By The Lake
SunsetSteve
Postby SunsetSteve » November 6th, 2020, 7:30 am
The replies are pretty much as I anticipated. I don't think our boat has a dockside water intake system - at least I haven't located an intake thing aside from the filler cap on deck. My marina has municipal water at the dock, and a small filtered extra-potable water thing available near the office to fill drinking water bottles. So . . . makes one think.
The living space and features on this boat far exceed that of my old Albin 25 diesel, and we are excited to begin enjoying her in the spring. Just now the Riviera is in my yard waiting for the shrink wrapper and a decision on a new name ("Open Water" doesn't have the excitement/adventure level that I want!). :captain:
Cooler
Postby Cooler » November 7th, 2020, 11:06 am
Steve, it would be strange if you do not have a shore water connection, especially on a Riv which is designed for live aboard. Call Carver with your hull # and they can tell you if that connection is installed, and where it is. Sometimes they get confused with the washdown system, if there is one of those. Sometimes they are in some pretty obscure places. Good luck! 8-) er
Cooler By The Lake
Cooler
Postby Cooler » November 7th, 2020, 11:09 am
If you can't get in touch with them (Covid), just provide your hull #, and I can drive out to the factory and check it our for you. I live about 12 miles from the main plant/office. 8-) er
Cooler By The Lake
SunsetSteve
Postby SunsetSteve » November 7th, 2020, 12:11 pm
Than you Cooler - very generous of you.
I will try calling Carver but just in case, HIN is CDR800039182-83
