Circuit Breakers
Gary Rose
Vessel Info: 2000 356 carver aft
Has thanked: 5 times
Been thanked: 3 times
Circuit Breakers
Postby Gary Rose » November 28th, 2020, 10:21 am
I have a 2000 356 and I am looking where to get the main 110v breaker for my boat. It is a 3 pole breaker but only has one switch. Tried West Marine but no help. Any Ideas ???????????
Re: Circuit Breakers
Postby Midnightsun » November 28th, 2020, 11:02 am
Try searching on Blue Sea site, probably supplied/made by them. https://www.bluesea.com/
Postby km1125 » November 28th, 2020, 11:28 am
They are out there. What style is yours... a rocker or a handle?
Here's one example, but it could be a Blue Seas or a Carling:
https://www.iboats.com/shop/paneltronic ... -coil.html
Gary Rose
Postby Gary Rose » November 28th, 2020, 11:40 am
It is a carling its a single handle part Number is ab3-x0-00-065-3d1-c. Carver part # is 8900333
Gary Rose
Postby Gary Rose » November 28th, 2020, 11:46 am
Postby bud37 » November 28th, 2020, 12:03 pm
There should be an id sticker on there ....if so just get the info from it and match up......you can get them on Amazon as well.....probably Carling unless it has been replaced before you.
Fyi any switch you consider....just double check the spacing for the mounting screws...
Liechtenstein
chpsk8
Has thanked: 27 times
Been thanked: 76 times
Postby chpsk8 » November 28th, 2020, 1:06 pm
Try Great Lakes skipper .com or fpmarine.com. Both have a lot of choices for breakers.
vineyardgray
Has thanked: 128 times
Been thanked: 33 times
Postby vineyardgray » December 1st, 2020, 5:21 pm
I had a similar three pole, single switch breaker and was told that they don't make them with internal links any more - I had to get one with two switches with an external "joining bar" (there is a name for this link but i'm drawing a blank)
It still fit in the same spot - just needed to drill another hole.
M/V Gilded Splinter
1988 Carver
3867 Santego
PCYC
Return to “Electrical”
